Boston Habba
Thread starter- Joined
- Jul 26, 2003
- 65
1986 175 HP v6<br /><br />OK, who can explain this? I'm having a stalling problem. Not a very serious problem but a real irritating one.<br /><br />I'll give you a typical example. Start the engine -no problem. Run the one mile to the fuel dock -no problem. Turn the engine off, fill up and restart - no problem. Leave at wake only speed (about 1200 rpm). Go a couple of hundred feet and it looses power and stalls. Hard starting but will restart. The same thing happens even if I've been running a long time before shutting the engine down. If I don't turn off the engine I can go all day at trolling speed (1000 -1200 RPM). Replaced the fuel pump diaphram and gaskets, but not check valves because the shop said that they almost never go bad, in fact they don't even stock the check valves. No change.
