cntrllglnn
Thread starter- Joined
- Jul 17, 2009
- 35
I have another (older) thread on this motor and instead of adding a different, but similar topic of discussion thought it'd be best to start a new thread. I've rebuilt the carb with a kit minus the float bowl. The coils each ohm at 4.69, points have plenty of padding on them and gapped at .020 at WOT. It had a NOS mag plate put in yesterday because the other had a significant amount of side to side and up and down slop that I believed to either not be opening or closing the points correctly or properly. Plug wires have quite a bit of resistance plug cap to end (out of the coil for a truer reading); now mind you these are automotive (fiber) plug wires and all I had at the time and WANTED to go fishing. O'Reilly's is getting in a new roll of copper cored plug wire in the morning so it'll get the plug wires that are suggested to be used. The motor ran rough before I believe due to the mag plate, but had never backfired when trying to fire her up. I got in a hurry and didn't pay attention to whether the front coil (by the carb) goes to the top or bottom plug. So i have two questions for the experienced OMC members. Thanks in advance for your time and knowledge it's truly appreciated guys.
1) What would cause the backfiring. Everything being the same with it running prior to changing the mag plate?
2) Which plug gets assigned the front coil by the carb?
