why won't the flywheel turn over manually
Pope_man
I had my Johnson 2004 140 4 stroke motor running fine and peeing for about 5 minutes and then it just cut off. I cannot turn the flywheel manually at all. Any ideas what it could be?
F_R
Disaster. Seriously, something broke or came apart. Can't tell what it was from a distance.
How did the motor run for you last season ?-----Checked the oil level in gearcase?-----Oil level in the crankcase ?----How fast was it running when it quit ?----Make any noises ?
440roadrunner
Does it move at all? Does the prop turn in neutral? As said above, "could be" the gearbox
Flywheel magnets ????----Screw loose under the flywheel ?
