why the 7/16 gap testet in joe reeves method
adk_vfr
Hi just wondering what is the reason behind the gap tester set to 7/16 on #1 cylinder during Joe reeves method of wot timing. What purpose does it serve. Thank-you
adk_vfr
Re: why the 7/16 gap testet in joe reeves method
Just curious what the 7/16 gap does for the procedure.
wilde1j
BC that's the min. gap the CDI ignition should jump. If it doesn't, you need to troubleshoot.
Haffiman
The 7/16 gap does nothing for the WOT adjustment, but if no spark at that gap-setting, your ignition system does not give out the power it should. It will need above 30KV to jump that gap.
Another thing is that some 'cheap' timing lights gives erratic readings if the voltage gets to low in the plug lead.
seasprayralph
Hi, dont go out and buy a spark tester,, if you look at my post from last week you will see how easy and cheap it is to make one,, and for the record,
Joes,s timing method is excellent, my motor runs great after using it,.
adk_vfr
Thanks for the info already bought one for 4 bucks at advanced auto
