Why So Much Oil?
bigfishcatcher3
Here is a 89 Johnson 25 J25RLCEM. I died on me last weekend. Good news is that I found the issue after removing the flywheel. The 2 wires that connect the charge coil to the power pack(CDI), well one wire was cut/burnt right through. Ok but why all the oil? Is it a crank seal? Now when I grab the threaded top of the crank and wiggle it I can make a slight knocking noise lower in the engine. Should there be a little play or could a bearing be my issue? At this point the peak of my fishing season I am tempted to replace the parts and address the oil issue as a winter project because a seal bearing project sounds like a major overhaul for limit motor experience. What do you guys think? Thanks in advance for any input.
F_R
Honorary Supreme Mariner
There shouldn't be any oil under the flywheel. And there shouldn't be any lateral play in the crankshaft. If there is, that probably is why the seal is leaking. But also, if there is lateral play, the leak is the least of your problems. It will soon fail dramatically.
However, on the bright side, maybe the upper crankcase bearing housing loosened up. Check that before freaking out.
There is no crankcase " upper bearing housing " on this motor.
