bigfishcatcher3
Thread starter- Joined
- Mar 29, 2014
- 5
Here is a 89 Johnson 25 J25RLCEM. I died on me last weekend. Good news is that I found the issue after removing the flywheel. The 2 wires that connect the charge coil to the power pack(CDI), well one wire was cut/burnt right through. Ok but why all the oil? Is it a crank seal? Now when I grab the threaded top of the crank and wiggle it I can make a slight knocking noise lower in the engine. Should there be a little play or could a bearing be my issue? At this point the peak of my fishing season I am tempted to replace the parts and address the oil issue as a winter project because a seal bearing project sounds like a major overhaul for limit motor experience. What do you guys think? Thanks in advance for any input.
