Why no kill switch on 1975 15hp Chrysler outboard ?
Status
Not open for further replies.
Idahored
Just bought another boat, which has a 15 hp Chrysler outboard on it. I found the original sales invoice which shows it was purchased in June 1975. The guy I bought it from, said it has no kill switch,and the only way to shut it down, is to pull out the choke. Over my 79 years, I've owned a bunch of boats, big and small, but this is the first I've came across that had no kill switch. If this is the way Chrysler made them back then, I'm wondering if there may be an after market kill switch that can be installed ?
Idahored
Mtn Home, Id
Nordin
Idahored yes "early" Chryslers had no killswitch BUT 1975 in those days it should have.
I know prio about 1972-73 you have to choke the small Chrysler to shut them down.
There are aftermarket kill switches, buy one with normaly open function.
If the engine has points ignition system connect one wire at each points and connect them to the switch.
It should make a short between the points when you push the button to shut it down.
legalfee
The diagrams I've seen show a yellow wire at the starter solenoid going to a neutral safety switch.
ollyolly1964
I've the same.problem but it's a 12.9 crysler was given to a friend.done most things but can't move the steering king pin.but up and down is OK.also does any one no how to wire in kill switch as not to sure.
The Force power
Please read the forum rules;
#12. Please do not post to threads that have been inactive for more than approximately 3 months UNLESS you are the original poster.
We have very active forums and any thread that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old thread. This is considered a hijack.
Hijacked threads may be closed and hijacking posts may be deleted or moved at the discretion of the Administrators and Moderators.
Please start a new thread of your own for the best possible help from forum members.
Captain Caveman
Maybe Chrysler figured that they would die on their own, so why bother with a switch?
None of my 50s or 60s Johnsons have kill switches. Just throttle it down to nothing.
Nordin
ollyolly1964, the same wiring as I deschribe for the 15Hp 1975 at top if this thread.
Status
