lncoop
Thread starter- Joined
- Apr 18, 2010
- 5,147
Re: Why Are My Brakes Suddenly Locking Up?
Allrighty. I'm not certain, but I think I've cracked it. I put the coupler back on this morning and bled the driver side with no trouble. When I attempted to bleed the curb side I pushed against the plunger so hard the shaft of my screwdriver was bending, but there was barely a dribble coming from the bleeder. At that point I began systematically disconnecting one fitting at a time starting at the MC and pushing fluid. After I flushed the last point I jacked her up and noted satisfactory performance, so I took her for a test drive. Once I returned I jacked her up again and the wheels were dragging slightly. I adjusted the curb side, but the star on the driver side adjuster won't turn a click, even after being introduced to penetrating oil, big channelocks, and a hammer, so I pulled it to take to the trailer parts store Monday. I'll probably also go ahead and replace the shock absorber while I'm at it. I can slide it by hand, but it doesn't seem to be a hundred percent. Once I get that done I'll test her out and report. Thanks for the input everyone.
