Why a basement garage is best
chambers1517
Our first house had a basement. Half was finished and half was used as a garage. I had kept my boat in the garage and it stayed around 50 degrees all winter. We sold the house and bought a new one. The new house had a nice garage on the side of the house but if it was 20 degrees outside it was 20 in the garage. 4 years ago we built a new house. To put the house on a basement was about as much as doing a garage. Definately wanted to go basement. Half garage and half finished. Now my boat has a warm place to stay. Don't have to heat the garage and it stays 50+ degrees all winter.
Triangleboater
Totally agree with you, my basement stays around the same all winter. But when it rains a whole ton we have water intrusion issues :(
Triangleboater
dingbat
I have never understood the desire to keep a boat in a heated space. My boat spent a it's first 10 years of its life under a tarp. It now lives in a equipment shed. It's never complained of being cold......lol
chambers1517
I had a brand new boat in 1994. I had a rental house with a covered carport I kept the boat in. I also covered the boat in the winter. My current boat is six years old and has been garage kept. It looks brand new. My first boat had cracked vinyl after 5 years. I probably spent more time treating and cleaning the vinyl on the first boat also.
haulnazz15
My boat has sat in a drafty dirt-floor barn for ~15 years, then an unheated/uninsulated 2-car garage for a few years, and now a 30x50 shop. It hasn't ever failed to operate because it was "cold". The only difference between keeping a boat in 50-degree temps and 20-degree temps is whether or not you decide to winterize it. I don't ski when outside temps get into the low 60's, so there's no point in keeping water in the block from Nov-Mar here in Oklahoma. Also, almost no one has basements here because the water intrusion is so bad.
chambers1517
To me also the biggest advantage is whenever I feel like it I can tinker with the boat.Currently my speedometer doesn't work. Something great to work on this winter.
roscoe
Hmmmm, my garage stays above freezing inside, until the outside temp drops to around 7-10*F.
Garage is better insulated than my house.
Stays around 50 inside when its 32 outside.
My sister has a 2800 sq' house, with an 1800 sq' basement, part of which was, WAS, a 20 x 30' garage / wash bay.
After one winter, the basement garage door was removed and a new insulated wall installed due to the cold intrusion.
Basement stays much warmer, and kitchen and dining room above the garage are much more comfortable, as is the heating bill.
Thinking it is a better idea to spend less money keeping the boat warm, so there is more money to fuel the boat addiction.
blackhawk180
I keep my boat in a carport which works great but in early winter, I move it up to my buddies glactic big heated shop for a month of "maintenance" (some alcohol is usually involved). I'm pretty sure the boat doesn't know the difference but I sure like working in 60+ degrees instead of 6 degrees.
dingbat
I see a bit of logic here....:)
25thmustang
No luxury of getting the boat inside. Only cold nasty outdoor storage is an option.
Tnstratofam
I don't keep my boat in a heated garage so the boat stays happy dry and warm. I keep it in a heated garage so I stay dry and warm when the Admiral kicks me outside for annoying her.:D
Vintin
If the boat is stored under a heated living space please have a master electrical switch on the batteries.
keith2k455
I hear you on the temp, but disagree with the basement. My first house had a 24 x 30 basement garage....problem was eventually had daily drivers sitting outside for the toys to stay inside over winter.....a little problem I IL. New house has an attached 3 car that is 970 sq ft. Doesn't cost but about 10 bucks a month to run the garage heater at 52*...except last winter on those -20 days.
JimS123
My basement has a rec room with a pool table, a workshop for woodworking and ammunition reloading, a laudry room and a sewing room. All very dry...no dampness at all. If I had a basement garage I wouldn't be able to do any of this because they are wayyyy too damp in my area.
My 5 car garage is attached to the house and fully insulated. No need to heat it. 3 cars, the family boat and a jetski live there year round. Last winter (the Bad one) it went below freezing only 3 times and those were days it was below zero outside.
Cold doesn't hurt a boat - its dampness wetness and UV that you need to be concerned about.
chambers1517
The thing about the basement, at least if it is mostly underground is the fact the heated space above radiates to the basement and keeps it warm. There is nothing to radiate to a garage on the side of the house.
JimS123
In the built environment, the major heat loss is through the windows. The next is through the walls. Third is through the roof on newer homes because that's where the most insulation is. Old houses may be a different story. The degree of loss depends on the thickness of the walls and the R value of the insulation within them.
Any house loses heat through all 4 walls and the ceiling (roof). The attached garage merely takes advantage of that loss by capturing some of it. That's why an attached garage is always higher temperature than the outside (assuming it was insulated as well as the house).
An enclosed basement retains more heat than the garage, because its underground, which is even better insulation. It also captures more of the heat loss from the house because the first floor floor is usually not insulated. Once you open the basement to an exterior door though, you increase the amount of heat loss, plus take in more moisture from the outside. Damp basements are not fun!
In my case, if the house is set at 70F, the basement equilibrates to about 66 with no heat ducts open. If the outside is 25, the garage levels out at about 34. For the garage to get as low as about 25, the outside temp has to drop to below zero.
I work on my boats and cars in the garage year round. If its 35 out there on a day I have off, a small electric space heater warms the area up just fine. Actually, 35 is about the best temp for waxing.....that's when I get the longest lasting job.
gddavid
My father built a fiberglass jacuzzi in our basement garage when I was a kid. The fumes and fiberglass dust that made it's way throughout the house was so bad that it convinced my mother to approve the construction of a 2.5 bay pole barn behind the house for future projects. The basement garage was drywalled and seperated from the other half of the basement with an exterior type door but the polyester resin off gasing worked it's way up through the house anyway.
My house has a garage door into the basement and a detached garage as well, I will never forget that experience and never fiberglass in my basement. Aside from that I wish my boat would fit through my basement garage door. I would love to slip downstairs and tinker with it on winter nights in comfort without having to heat the whole garage up.
