which type of u joint do i have????
Tailguner
I have a 2000 bravo 3 serial# OL743969 and i want to change the u joints but dont know if i have inner or outer clips. Want to replace with spicer or trw or something similar.Anyone know??? what aftermarket u joints will work???? thanks in advance
Fun Times
Tailguner
I show the current part number to be 865496A02 which supercedes 865496A01 which I got off mercruiser parts dot com going by my drives serial number....so now more confusion.....got to love it..:lol:
HT32BSX115
Take your U-joints to any good driveline shop and they will match them up with either TRW, SPICER or Neapco. ALL are just fine.
Mercury makes U-joints just like they have their own refinery!!!!! (NOT!!)
Cheers,
Rick
Fun Times
Using the serial number you provided, Here's your drive shaft parts catalog, http://www.mercruiserparts.com/Show...=210&bdesc=UNIVERSAL+JOINT/SHIFTER+COMPONENTS
Here's your complete list. http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=809808+96
Found the mistake! Your serial number is 0L, the part number you found fits 0M and up not down. Also the system looks to have been looking in the 0M100001 THRU 0W249999 serial number range but should have been in the 0F730000 THRU 0M100000 range.;)
2475832T1--CROSS AND BEARING (click here) SN# 0M111207 & Below$64.08$60.352
24865496A02--CROSS AND BEARING (click here) 865496A01SN# 0M111208 & Up$204.92$184.742
Tailguner
Thank you so much....i knew I would get the correct info here as always.
