Which piston do you recommend and why?
jb70508
Rebuilding my Johnson 115 Crossflow V-4, boring .020 over. Should I go with forged or cast pistons? Looking at either Wiseco or Pro V. Any suggestions are appreciated.
RCO
I would use the factory BRP. Look at how long the originals lasted.
interalian
I got 35 years out of the original 'rude pistons. I put BRP back in. They seem to be working.
jb70508
I've been told that the OEM pistons have problems with the rings breaking. That is the reason for my rebuild. Kind of leary about putting the OEM pistons back in after hearing this.
jb70508
I'm going to see the guy doing the boring on my motor and get his opinion as well. He raced boats for many years here in Louisiana. Just trying to gather as much feedback as possible. Thanks for all the replies so far
interalian
If other aftermarket pistons use the same style of compression-back rings, the results from them would be the similar to OE, no? If they don't, it's a different game.
jb70508
From what I am told the ring lands on the OEM pistons wear which causes the rings to break.
Faztbullet
That's only 1/2 the story...... The piston rings are all interchangeable between the OEM and aftermarket pistons except for Siezcos as they use straight ring lands.If this was the problem the aftermarkets would have changed the design. The reason they break rings is due to engine running to cool and the ring lands coke up. This builds under ring and causes it to flutter and wears land and pushes it out till it hangs edge in port and rolls ring. Use a cast piston,bore to proper size, replace all items in cooling system and use proper oil ratio.
jb70508
Update on my rebuild. Finally got her all put back together. Bored .020 over, new WSM pistons, bearings, seals, water pump kit, thermostats, and carb kits. Started her up this morning and I think she sounds good. Check out the video of her running. Does she sound ok? Should she be peeing a little harder than she is? Still have to take her to the water to set my timing and idle. Won't be able to till next weekend. Thanks for everyone's help!!
