I've been told that the OEM pistons have problems with the rings breaking. That is the reason for my rebuild. Kind of leary about putting the OEM pistons back in after hearing this.
That's only 1/2 the story...... The piston rings are all interchangeable between the OEM and aftermarket pistons except for Siezcos as they use straight ring lands.If this was the problem the aftermarkets would have changed the design. The reason they break rings is due to engine running to cool and the ring lands coke up. This builds under ring and causes it to flutter and wears land and pushes it out till it hangs edge in port and rolls ring. Use a cast piston,bore to proper size, replace all items in cooling system and use proper oil ratio.From what I am told the ring lands on the OEM pistons wear which causes the rings to break
