- Jul 23, 2011
- 52,318
restoring the hull will cost you a minimum of $3000 on materials alone. since the transom is soft, you can put the key-holes anywhere because the transom will need to be replaced.
measure the center to center distance of the keyholes. if your over 33", you can shoe-horn some V6's or V8's in there. I would prefer 34-36", however 33 is the minimum per the mercruiser installation manual. (28" on in-line motors)
