Which outdrive will fit my motor?
Blueghost924
Hi, I have a 4 cylinder Mercruiser 470 3.7L engine. I currently don't have an outdrive, but which models will fit my engine? I was thinking the 80s Alpha 1 gen 1 or 2. Thanks.
Re: Which outdrive will fit my motor?
I believe the 470's had a 470 specific MC1, however I am going off of memory.
Ayuh,.... I believe the 470 was dead, 'n gone, before the Gen.II was introduced,...
So,... An Alpha 1, with 1.84:1 gear ratio is what ya need,...
Even if yer's was originally a MC-1, the Alpha 1 will bolt right on, 'n run just fine,...
thumpar
Make sure you get the correct drive shaft length. I know some used different lengths.
cruzn
No, I don't believe there were different drive lengths. Outboards had 20" or 25" shafts.
Blueghost924
Aye...thanks for the info.
thumpar
This is an I/O. On some Mercs I/Os they had 2 different drive shaft (shaft from the engine in the boat to the outdrive) lengths.
Ayuh,.... That's Correct,....
Only the In-line motors, from GM, when used with the MC-1 drive, use the just over 8" input shaft,....
All the other combinations usin' the MC-1, Alpha 1, Alpha 1, Gen.II, 'n many of the Bravos, use the just over 9" input shaft on the drives,...
Blueghost924
Do you think an Alpha 1 from the 1983-1990s year range with a gear ratio of 1.98 : 1 work?
Ayuh,... That'll depend on what prop pitch worked properly with the 1.84 ratio,...
Blueghost924
I was told that the Alpha 1 with a 1.98 :1 will bolt on fine and work properly, but because of the different gear ratio than a stock ratio, it will get up on plane faster but lose some top end speed.
thumpar
It is not that you will lose top end it is that you will over rev the engine unless you can find a prop that will compensate.
