Which one
ericcarr2000
Ensign
Ok as many of you may know I recently purchased a used 89 trailer online that some of you say I should use a different one to travel with.
I just ran across this one instead, it is a 96 fast load trailer, which one would you guys recommend on using?
bonz_d
Re: Which one
Sorry I didn't see your other post so am not up to date but I really do not see much difference between the two trailers. They look the same only with different bunks.
smokeonthewater
Re: Which one
We've already told you how to determine the capacity of a trailer and what your boat should weigh.
Beyond that the trailer that is rated for the weight, able to fit the boat, and in the best condition is the one to use.
Those pics don't really tell us much.
Triangleboater
Re: Which one
Also in the previous thread I mentioned looking at the brakes. The fast load, does it have electric brakes? Does your tow vechicle have a brake controller? I thing the first trailer had surge brakes? Looks like the fast load might fit your hull better.
But like smokeonthewater said, we need to know weight capasity! What they look like doesn't really matter.
Will it hold the weight, how will it hold it, and will the brakes work to stop it.
