which oil?
gonefishin72
hello all. newbie here.
Just picked up a different boat and its been sitting along time. Its an 89 bayliner capri 19'. It has the force 125 outboard but mounted like an inboard. (L-drive). I know, I hear now that its junk but i'm stuck with it. I got it started the other day. runs like a top. but since its been sitting for a number of years i know there are things that i should check. my question is: what oil do i use in the lower unit and where is the fill and drain plugs? i havent looked real close yet. Also i should probably change the water pump impeller or the whole pump. any other suggestions as to what all i should inspect before launching the boat?
fat fanny
Re: which oil?
Check out the stickies @the top of the forum. Not real familiar w/ that setup but others will definately chime in soon thats one thing you can count on here. Welcome aboard and you'll love the help and resources here. but check out the stickies section for starters.
Don S
Re: which oil?
Welcome to iboats gonefishin, it's still an outboard, not an IO so will move this over to the Force outboard forum.
