Which manual. Seloc or Mercruiser?
3ball
I need to get a service manual for my engine. What is the difference between The Seloc manual offered here on iboats for $25 and the manual that Mercury Marine offers for $99?
Someone told me i needed this manual in a previous post
#31 V8 ENGINES 5.0, 5.7, 6.2 Part number 90-864260T00.
is that a Merc # or a Seloc #?
My engine serial number is - M320848
QC
Re: Which manual. Seloc or Mercruiser?
The main difference is that the Seloc belongs on a roll in the head . . . Take a look at the Adult's Only sticky above ^^^^^^^
fishrdan
Without a doubt,,, the Mercruiser manual!
#1 Because it's accurate and will have the info you need.
#2 Because it's (most likely) downloadable for free in the Adults only section.
JoLin
Slightly different opinion. I say both. There were times when servicing my Johnson outboard, that the factory manual would confuse me because it's written for trained mechanics.
Seloc sometimes presented the same instructions in a slightly different way, and/or with a different graphic. Between the 2 of them I was always able to figure it out.
If you can, buy both (plus an owner's manual and parts catalog- it shows how things fit together).
If only buying one, the factory manual is way better.
My .02
3ball
Thanks everyone, just downloaded it. I think I will also get the Seloc version, it's nice to have something in hand rather than on the computer. John, you make a good point about different explanations on the same thing.
Gary H NC
Anything you read in the Seloc be sure to go back to the factory manual to verify the info.
I have seen just completely WRONG info in the Selocs.
zbnutcase
Yes typo's happen a lot in the aftermarket books.
