Which Hub?
al2ride
I finally removed the melted hub from my prop. Part number on the prop is 48-88440-19 and goes into my 95 Mercruiser 4.3lx Alpha One Gen II. I couldn't find a part number on the old hub. Does the prop use a Flo Torque II hub? Thanks in advance.
al2ride
Re: Which Hub?
Donno,... Got a picture of it, both ends,..??
I took pictures of both ends but they are too big to post. The prop has what looks like an even cylinder, unlike the flo torque which has a square type. It must use an older type of hub.
Re: Which Hub?
Ayuh,... That would be My guess,... A Prop Shop can fix it up...
extreme76
Re: Which Hub?
Nothing wrong with the prop...the hub spun out that's all. I just need to order the correct hub for it.
What Bond-o was referring to is it takes a "pressed-in" hub. It isn't one you just slip in by hand. Most of us don't have the equipment to do it and would take it to a prop shop to re-hub.
al2ride
Re: Which Hub?
Ah, okay...didn't know it was that type, but it makes sense. Anybody know the part number for the hub?
Re: Which Hub?
Ayuh,... If it is a pressed in hub, you ain't gonna buy 1,...
Bring it to a Prop Shop for repairs...
At the top of this forum are instructions on resizing, 'n posting pictures...
