Wheres the coolant going? MC 5.0
rick3452
Back to my coolant loss. I believe that i may be losing coolant into the cylinders. The reason i think this is happening is recently on first start of the day the starter almost sounds like it binding for a second. Then starts and runs perfectly and will restart the rest of the day. I replaced both manifolds and risers about 1 year ago and used oem gaskets. The oil is clear and no other signs of leeking. Could it be internally between the riser and manifold and should i torque the bolts a bit more? Closed system. Ser. 0m012817. Carbed. Bravo 3
Thanks very much. Rick
Re: Wheres the coolant going? MC 5.0
Ayuh,.... 1st thing I'd do is,.... Go pull the spark plugs, 'n spin it over to see how much coolant, 'n from where....
Then I'd drain the coolin' system, 'n Pressure Test it....
All before I tried to start it again,..... yer lucky if ya ain't already bent a rod...
rick3452
Thanks Bondo, Question, if I pressure test the closed system and it IS leaking at riser gasket but not visible to the outside will I be able to tell if its leaking into the
manifold ? Thanks
manifold ? Thanks
Ayuh,.... Pull the rubber boot back, 'n you'll Hear it leakin', Inside...
Remember to drain, before ya start.... ;)
rick3452
Thanks will do, but in Massachusetts right now visiting the grandchildren, as soon as I get back I will test and report back...
Rick
