Where to put speakers on Party Barge 21
bobvonryan
I have a new Sun Tracker Party Barge 21 and need more speakers in the back of the boat. I just can't figure out where to mount them. Any suggestions?
samm835
Re: Where to put speakers on Party Barge 21
I have two on each side of me seats in the back, but I also made two box speakers for my ten inch speakers. I made them out of plywood, and then enclosed with fiberglass. It was really easy to make and cheaper to make then to buy them also. I don't know if you have room, but my buddy has one 6x9 mounted in his console on the side about 8inches off the floor as well. Any place you can find that they won't get drenched and they have a little room for air will be good. Also if you build your boxes you can form them to fit in any corner that you need.
EricStarr
I added to to the back of my suntracker i just used a roto zip and cut the plastic base for the seat and mounted them looks good to.
lncoop
Yeah, I have a 21 footer as well and that's about the only place I can think of where you could put them. I might do that myself. The sound from the front speakers reaches the back of the barge even when underway, but if you have them that loud the people chilling on the front get an ear full. You could also use a hole saw bit or drill a pilot hole and finish it with a saw if you don't have a rotary tool. Let us know how it turns out so you can be my guinea pig.;)
bobvonryan
Thanks for the replies! I guess I will get the rotozip out and put them under the L shaped seat in the back. One on each ELL. Hopefully it will sound ok.
