76SeaRay
- Aug 24, 2017
- 1,047
Yes, I foamed under the floor. No, I wasn't worried about the foam cracking the ABS pipe. I filled through 1 1/2 inch holes so any over expansion could escape anyway. ABS pipe is pretty strong. I have a galley and the water tank is on the port side but the sink is on the starboard side plus there are wires for the water tank pump. I ran those in ABS as well back to the fuel tank area on the port side, across the top of the fuel tank and inside additional ABS pipe run next to the pipe for the fuel and vent lines. I found it almost impossible to run the vent line and the fuel line in the same pipe, however, I also had two bends in my lines like an "S" curve.
So, I have one pipe on the port side for the water line, water pump wires, and miscellaneous wires. I have three pipes on the starboard side; one for the fuel line, one for the fuel vent line and tank ground line to the fill port, and one for the water line and wires from the port side.
