Where to get tires cheap?
lmannyr
Master Chief Petty Officer
Looking to replace all 4 tires on my 7k lb capacity trailer. 205/75-14
The Best deal i've been able to find has been online at trailertires.com
4 tires shipped = 291.86
This is tire only. I'll be mounting them on my newly painted wheels.
Thanks...
Mark42
Re: Where to get tires cheap?
Thanks...
Bias Ply or Radial?
tashasdaddy
have you tried any of the local tire stores. there is a place here, mounted and balanced, $240.
redfury
Thanks...
Check out Discount Tire, they usually can beat any price online, and the mounting will be included in the price.
180shabah
What's on the neighbors trailer? He can't watch it 24/7
Gary H NC
LOL!!
I have 5 brand new tires that size that are radials.Have them wrapped in plastic behind the garage.They are extras for my travel trailer.
If he was close by i could make him a heck of a deal but shipping them would be expensive...
salty87
ntb, and i'm sure the others, can get whatever tire you want. they'll price match too.
lmannyr
Got a quote today from a local seller for 240 balanced and mounted on all 4 tires. Never heard of the brand. I'll just keep them max inflated and hope for the best.
reelfishin
I found tire rack one of the highest priced on trailer tires. I just bought 8 pair of 13" load range B radials for $33 each and two bias ply 13" tires for $28, they were all branded either Nanco or Towmaster. All but one of my trailers uses 13" so I get to run cheaper tires, but they did have 14" bias plys for $42 and radials for $52. This was back in late July.
I picked them up in person, no shipping, no mounting or balancing.
Since I buy often and probably buy a few dozen sets per year, they do cut me break. It's pretty much the same price as the better priced online sources sans shipping.
Keep in mind that ontop of the $99 Tire Rack wants per 205/14 tire, there still shipping. The nearest store to me is about an hour and a half away and they won't sell unmounted tires, so they can charge you a fee to mount and balance each tire. When it comes to low dollar tires online in general the two sources I've found have been wholesale trailer supplies.com and Nebraska Tire.com. But I've always been able to find equal or better deals locally on larger or high shipping items. From a reality standpoint, it should cost no more than $10 per tire to ship a tire, often less. Many charge over $60 to ship a set of four tires.
Majormike
I agree with Reelfishin, the shipping is outrageous with on-line purchasing. I've been looking for 225/75-15 and $25/tire for shipping seems to be pretty standard. At that rate, a set of four will run me just under $500 and that's before they're mounted. I'm checking local prices....
Shinok87
why are you looking for cheap tires? those tires will be hauling your boat and if they fail you boat goes too. take care of your toys and drop some money on some nice tires.
reelfishin
I'd rather have cheap new tires than old, dry rotted tires any day. Some folks just can't afford the price that they want for some of these tires these days.
There's also a difference between getting cheap tires and getting good tires cheap.
I just priced new tires for my car and the best local price for name brand tires was over $650, I got off brand tires for $225 installed with the same warranty.
I'd venture to bet that they will dry rot long before they ever wear out on that car much like the original ones did that only lasted 15k before they were so cracked and dry they were unsafe. They were on the car only 15k over a 6 year period. What sense would it make for me to spend $650 for high dollar tires when I drive the car maybe a few miles every few weeks. On a work truck that carries weight and runs a few hundred miles everyday I use better rubber but even there I've not seen a big difference between brands lately.
I also try to shop apples of apples, the ply count and tread thickness and rating makes a difference in how the tire will hold up more than the brand.
I had a driver puncture two front tires while out of state, the only tire dealer around with the right size tire in stock for the van had only Chinese el cheapo tires, that was a year ago and about 39,000 miles, they have worn just the same as the Firestone tires that were on it. Not that I'd buy them again, but at $59 per tire vs. either towing it home 200 miles or leaving it there vs. $159 for each for the identical replacement tire, I think I got my moneys worth out of them. The ride fine and have no issues. They look like Michelin clones but say Good Ride on them and made in China.
At $59 per tire and having them last a year and almost 40K on a 3/4 ton work truck the runs at highway speed all day long, I'd be tempted to buy them again. I've seen no drawbacks to those two tires as of yet, and they've still got more than 1/3 their tread left.
