Where to get parts?
fuzzeywiggler
I have a sad story indeed...(not really but its a bummer) I recently bought a 64' evinrude knowing it diden't have spark but ran a compression test and tested the gears before buying. When I got home I wanted to make sure there wasn't a fuel prob as well so I pulled the head and turned the motor over and sure enough I was getting fuel as I was putting the head back on I noticed something funny with the pistions, their blown!
Long story short anyone know good sites for ordering pistons, rings, gaskets?
Fuzzey
OBJ
Re: Where to get parts?
Fuzzey....give us a hp there partner.
Jim
fuzzeywiggler
Right..new I was missing somthing. Its 40hp
Fuzzey
fuzzeywiggler
Alright, now would newer parts (pistions) be interchangeable? if so what years?
Thanks Fuzzey
Basher
fuzzey,
what do mean by blown pistons? I don't believe you can get a good compression test on bad pistons. Are they scored, burned, cracked? If they look like they have a lot of burned crap on them chances are they are fine and a good decarb with seafoam will clean them up not to mention the carb.
Basher
F_R
Honorary Supreme Mariner
If you do need pistons, they are still available from Johnson/Evinrude dealers. You probably will have to update them to the newer Pressure Back piston rings, so you need a parts man that knows what he is doing.
fuzzeywiggler
fuzzey,
The piston has a hole in the top edge.. I would post a pic but I don't have an available camera.
I figure its from age everytime the pistion would hit TDC it would knock a little and wear down. and being a 64' I think its somewhat normal
Basher
ok thanks ill look for someone with weatherd hands :)
Fuzzey
fuzzeywiggler
fuzzey,
Basher
I don't think seafoam is quite gonna cut it ;). I have torn apart the carb and rebuilt it if I/when I get the motor running (if anyone is bidding on armature plates on ebay please don't;)) Ill get a carb kit
Fuzzey
Reggie08
No idea about your motor, but I just checked out your boat project and it's looking great!
fuzzeywiggler
Thanks Reggie,
I think a combo of ebay,outboard websites and johnson dealers is where im going to get parts from.
Fuzzey
