Where To Get New Coil Wire
bankermike
I have a CDI coil but I need a wire for it. I have a 1971 Johnson 60 H.P. The wire needs a female plug on the coil end and a screw in on the dist. end. I've looked on this site but can't seem to find one.
bankermike
Re: Where To Get New Coil Wire
The coil I need the wire for is not an OEM, it's a replacement made by CDI & it uses a different wire than the OEM coil. On the OEM coil the wire is made into the coil and on the CDI coil the wire snaps onto the coil like a spark plug wire.
Thanks
michael
tashasdaddy
from the research i did, looks like you will have to buy the kit., then just put the coil back reserve.
tashasdaddy
good call, learn something everyday here.
