where to get fuel pump for 1965 johnson 40hp
AlTn
Re: where to get fuel pump for 1965 johnson 40hp
boats.net and marineengine.com show pump 0388685 for $79
honda507
I installed a in line fuel filter after the pump in the line going to the carb. Could this be causing a problem? If i have the plugs in the engine and plug wires off then crank it over shouldnt gas come out of the exit hole in the pump?
honda507
Got it all figured out. Took it apart and found out i had one piece on the wrong way. Put it back together and works great now!
