Where to find specs
BryanJK
I'm looking at a 97 Glastron 1700 open bow ski boat. It's in pretty good shape but does need a couple things. I'll need a new starter solenoid, prop, and if I get real picky some small trim pieces. I'm wanting to find out how I can find what prop originally came on it. It has a 3.0 Mercruiser with the Alpha One. The current prop is a 3 blade aluminum that is bent up from a stump. I do recall seeing -15 at the end of the part number, not sure if that's meaningful. Either way I'd like to replace it with a steel one with the original specs. Maybe a 4 blade. Anyhow, where can I go to look up the OEM specs and parts?
Also, are those starter solenoids something special or like a standard 80's type Ford solenoid?
