exnavyman123
- Apr 17, 2010
- 123
into the foam filled compartments?
This is what I found :
a 1 /16th " diameter hole above the starboard side stringer, so not sure where the water can travel from there ...........
i found out that the previous owner screwed the bilge pump to the hull without sealing the mounting screw holes, the glassed in wood below it was saturated so i opened up the holes and sucked the water through the holes. I got about a beer bottle and a half worth out of there.
I figured i would start taking off the seats , driver, passenger, and the aluminum mounting base for the front pedestal seat and cutting a square away from the deck there and see what if any water has soaked into the foam and compartments.
I'd like to open this all up and investigate and air out some . I also wanted to use a grinder on the bilge pump mounting area and take the wood out and see what is going on under there. The pics show in order : 1st pic is of hole in corner above stringer (rust colored area) 2nd pic is of bilge pump mounting area and crazing, 3rd is of crack seeping water from the inside edge of the ski compartment.
I'd like to do as much as i can now and finish the job in the spring.
Thanks.
Thanks.
