where is the fuse panel located?
tube4fun
I recently purchased a 1994 Mariah Talari 180. The bilge pump is not working. When I turn the switch on it doesn't light up. I wanted to check the fuse first but couldn't find the fuse panel and had to leave. It's on the lift with the plug out and my 21 yr old son is still at lake but I don't want him tearing into everything trying to find it. Any help would be appreciated.
180shabah
Re: where is the fuse panel located?
I have a shabah, but mine is located under the starboard console. There is a flip up back cushion in the bow for access, or remove the panel under the dash.
Does your bilge pump have a float switch? It should. Do you have power to the dash switch? do you have power to the float switch? You need a DVM or you will waste a lot of time chasing your tail.
