Where is serial number on motor?
Cpell1984
Recently bought a 1998 Chaparral 260 signature with a 5.7 GSI throttle body injected. Wanna buy some parts for the engine but not sure what model gsi I have. My mercs always had the serial number on the plastic cowl cover. Looking to pick up new thermostat and gaskets as well as temp sensor, plugs, wires, cap and rotor.
Cpell1984
Trying to post a pic of my motor but says the file is to big 🙄
jmcr77
I just went through the same search. There should be a Volvo Penta sticker on the top but mine was rubbed out from age or wear. There is a stamped metal info plate riveted to the aft port side of the engine block.
Access for me was tight so the advice was to stick your phone down there and try to get a look that way which worked pretty well.
https://www.volvopenta.us/marineleisure/en-us/for-owners/your-engine/decals.html
https://www.volvopenta.us/industrialoffroad/en-us/parts-service/your-engine.html
Cpell1984
Thanks for the info. My sticker must have worn off also. I’ll def give it a look!
Reduce your photo to about 400kb (20-25%)
Look at the tag in the side of the block just above the starter boss
