strtbobber
Thread starter- Joined
- Oct 12, 2010
- 212
bobber;
here is a manual you can download for a 35 courtesy of Swamp Thing:
http://forums.iboats.com/showthread.php?t=464459
Page 18 for schematic.
Gerry
It's ok now, carholme, I got it downloaded! Thanks a bunch!!!
Yea you have to click slow download (it's really not slow) and then wait a minute for it to start. I think it's confusing on purpose. It's a PIA but it was the only place I could find to host the files. Hope it helped you. I'd be lost with out the manual - lol
bobber;
Glad you got it, with all the water, you may need it soon. I was there with a helicopter in the 97 flood but this looks like it may be worse.
Good luck
Gerry
bobber;
Can't determine if those wires are coloured or not, they may have been replaced but are they not the wires coming from the points to the coil negatives?
I will see if I can find a diagram.
Gerry
strtbobber haven?t you read my reply? It is for the killerswitch. Connect the two wires at the terminal at the exaustplate on the engine (no other wires connected) then if you have a ign.key you connect two wires at the terminal (exaustplate) to the keys two M terminals. When you turn off the key the M terminals short out together and kill the engine. Have a look at maxrules.com / tech.spec./ ChryslerForce wirediagram and then "klick" at 35-55Hp w/alternator. There you have the wirediagram for magneto ign. with points.
Sorry, Nordin, I think I misread yours the first time. Thanks so much for clearing it up. It makes more sense now. I'll give that a shot. Sorry, didn't mean to ignore your reply! Thanks again!!!
Alf;
Here is the direct link to the diagram. As you have stated that you have magneto ignition, you will not have coils. If you blow up the diagram linked you will see the two black wires going to the terminal on the engine and attaching to the blue and white wires which then go forward to the ignition switch, Blue(M) and White(M).
http://www.maxrules.com/graphics/force/wiring/chry35_55magneto.jpg
Hope this clears it up for you.
Gerry
My 1970, 35 HP Chrysler Mag Ignition System?s black wires appears to be on # 3 & 7 matched with white ignition wires (attached). A 55 hood is on the 35 HP. I hope this will help and I have many other pics if you need any. Good Luck! jow
Thanks, wick! I'll have to check to see if that matches where I connected mine. jow??????????
