Where Can I buy a GOOD fuel bulb?
Crappie_Fan
I'm tired of wasting my money on these dang POS fuel bulbs from walmart. I've been in the process of completely redoing my fishing rig, and figured I would check bulb for leaks or sucking in of air, well had a leak on one the crimp hose clamps. So I removed crappy clamp and replace with a good one, well this time I remove hose from engine and leave engine end of hose plugged. I can hear the fuel sucking into the bulb and then squirting right back into the fuel tank (this is a new bulb and hose setup also). Isn't the bulb supposed to be like a check valve? So now that I'm in debt from buying a new bulb every year, I was wondering if there is, or someone makes a bulb that really works and maybe even last more than one year? Any help would be really appreciated.<br /><br />Thanks guys
chris in va
Re: Where Can I buy a GOOD fuel bulb?
If you have a WestMarine or Boaters World near you I'd check and see what they have. <br /><br />I think I have the same problem...
marinemech1
sometimes even with oem bulbs you need to get rid of air in bulb once its full of fuel it should work ok
moderator1
Moving to outboard, non-repair.....<br />And, don't forget to check iboats for the fuel bulbs... :)
