500dollar744ti
Thread starter- Joined
- Jul 23, 2012
- 691
i've been pondering how i'm going to do this for a while. if my motor were easy to get to i would be opening the drains and letting all the water out manually, air can't freeze right?
well, my engine (1990 MCM 350 Magnum) sits low in the back and it's godawful akward to get to. after removing half the interior, it took me about 2 hours to change the plugs. i felt like i needed to be a contortionist to work on it. i have a feeling the drains are going to be even harder to get to and i'm pretty sure i'll have to remove a manifold and riser to get to the power steering cooler.
is there any reason i can't fill a garbage can full of that pink biodegradable antifreeze, put it under the drive and run it until it has been spraying out the exhaust for a while?
about how long does it take for the cooling system to completely circulate through the block, p/s cooler, heads, manifolds and all that? can i be reasonably sure that once it's spraying out the exhaust there's enough in there to prevent any freezing?
