What's this?
sogood
Hello all and season's greetings. Still familiarising myself with the ( 1990 Mercruiser 5.7 V8 ) engine in my boat and came across the attached. Looking through my Seloc owners manual didn't help so I was wondering if any of you wise sages could identify it. It looks like a coil or ignition amplifier of some sort to me. Thanks in advance.
GA_Boater
That's down in the bilge under the motor? It's something added looking at the yellow crimped ring connector or the ring has been repaired/replaced.
If none of us has an answer, trace the large wire to see where it goes.
sogood
Thanks for the response. Yes, it's down on the port side, just hanging there. I will soon be rummaging around in more depth and will trace the wires then. Just noticed it by accident and wondered.............Thanks again.
shaw520
Looks like a fume sniffer,.... I have one in my 230 weekender, slightly different
Fun Times
Can you get down there and read the red lettering on the unit?
Maybe a high bilge water alarm or possibly a transducer of some sorts.
Is it sticking out the bottom of the boat?
Bt Doctur
Ok , it`s a capacitor to filter the AC signature coming from the alt or to eliminate the whine from the alt in the radio
Bt Doctur
