Whats This?
billywhizz
when Removed my Alpha 1 drive unit from the bellows housing to replace the shifter cable this fell out on the floor? I cant see where it goes or what it does? any ideas? cheers
JustJason
Re: Whats This?
I have no idea what that is, or why it's even there. Whatever it is, it's not needed.
180shabah
Re: Whats This?
Not knowing exactly where it dropped out of, I would guess it fell into an open exhaust tube and was never retrieved. Either way, just a leftover from sloppy work.
Don S
Re: Whats This?
Part of an exhaust flapper.
billywhizz
Re: Whats This?
now that does make sense, it fell out of the exhaust hole/bellow, so should i be taking the riser off now, will it have caused damage to the engine running it without the flapper? thank you Don
ziggy
Re: Whats This?
how abouts maybe the part the flapper mounts into. that part mounts to the exhaust pipe, the flapper mounts to that bracket. you only have one of two. the other one is still mounted to the exhaust pipe..
maybe similar to these.
that's the top of the inside of a exhaust pipe of a 75 165hp L6. flapper brackets
billywhizz
Re: Whats This?
Right on it my freind! question answered, what does the flapper do? regards, Bill
Re: Whats This?
Ayuh,... It keeps backwash from flooding Up, into the motor, Destroying it...
Well worth Fixin'...
