badboatowner
Thread starter- Joined
- May 9, 2010
- 4
Located on my power trim system there is red block whatzitcalled to which the 12v red power cable is connected. I've looked through the manuals but could not locate a part # although I do see it in the diagram. I suspect this thingy is a 110A fuse - if so I know it is working but as I am unable to tighten the nut it needs replacing. I am troubleshooting the power trim system - starting with the physical layer. There is a clicking when selecting up/down so I suspect the solenoids - there is corrosion around there ... to the point where I am unable to tighten that red block whatchamacallit connection. I removed both solenoids and that block doohickey and plan to stop by West Marine to buy replacements, but would really like to know what that thingamajiggy is called on the chance they do not have one or know it's proper name.
Thanks folks.
Thanks folks.
