whats the gap for the points
wire2
Re: whats the gap for the points
For almost any points, .018"
The thickness of a piece of a soda can folded over 2 times. (3 layers)
lynnboy021
can i use a feeler gauge???
wire2
Of course.
I just mentioned the soda can (.006" wall) as solution for someone caught without a set of feelers.
Don S
First of all, we need to know which distributor you have.
The Delco distributor use a point gap of .022 and a dwell of 28? to 34?
The Prestolite distibutor use a gap of .016 and a dwell of 39? to 45?
Odd, no where does it say .018, but it would run at .018.
You still need to set the dwell as the final setting, not just the gap. Gap is for preliminary setting only.
Oh, then you have to reset the timing, Dwell effects timing.
sgt
for a 488 merc 4 cly????
the proper gap would be .016 or 32 degrees in using a dwell meter. My suggestion would be to change it electronic ignition. Hope that helps?
Don S
Ok, you're the new guy, explain to me just how you know for sure which distributor he has ?
lynnboy021
lol guys i have delco and yes i forgot i had the manuel for my motor ok now what is a dwell and how do i set up the dwell??? i mean my bro in law just put points in his motor and thats all he did no timing or dwell motor works wonders but is it something i should do though????/
cr2k
point gap effects Dwell, Dwell effects timing. Fact of life. Be sure to grease the dist. cam too.
Always set the timing last.
lynnboy021
sorry i am dum i dont get it how to set dwell?????
