What's in your Boat Toolbox?
roscoe
Re: What's in your Boat Toolbox?
used to carry a box in the boat, but it got to heavy and I could no longer get up on plane.<br /><br />So I replaced it with a kicker motor, spare key and plug, tylenol and water.<br /><br />Eveerything else stays in the truck.
alderman
Don't do it with fuel in the line, guess I should have covered that. No accounting for common sense.<br />Ray
Buttanic
Mask, fins and snorkle, never know when I may need to go overboard because of a fouled prop or a hole punched in the hull in an area that cannot be reached from inside.
phaeton
much of the above tools wise but I would the following specific additions - <br />1. self amalgmating tape - rubber based and will provide a good tempory fix to most pipes.<br />2. one of those camping wire saws - about a foot of 'rough wire' between a couple of rings or toggles as handles. Almost unbeatable for removing rope from props/drives/rudders. I keep mine dry and handy in the flares box.
jtexas
Originally posted by garycinn:<br /> In addition:<br /><br />An extra boat ....
there you go, what else would you need?<br /><br /> :D :D :D :D :D
Solittle
While not a tool I won't leave the marina without marine charts.
Osprey
For those with thru-hull fittings at or below the waterline. A set of wood cone plugs used to cork the hole if one fails.
Ouan
Full set of sockets scerwdrivers hammer spare impellers oil filter woodworking tools wire spare light bulbs etc all my tools go to the boat when it goes in as well as some of those plastic sawhorses just about everything to fix everything !!
DeltaDaze
In addition to a lot of the suggestions above, a beeswax toilet ring seal. If one gets a hole in the boat, it can be easily molded to either plug the hole or to form a ring where one can stick plastic to it to cover a larger hole.<br /><br />DD
