What to look for in a project boat? Plus a few other questions
SkaterRace
I have been tossing around the idea of building a project boat for fishing since I would like a project to work on as well as want a fishing boat of my own (currently use my fathers but seeing as I will be moving in 2-3 years it won't be close anymore).
I have done a transom replacement before and while no fun due to the reason why - someone crashed my boat - I have no issues doing the work and learning. For me, the cut-off point is engine work since I despise that. I have a good guy who will do all of that for me and has for years so I should be safe on that route.
With that all said, what do you guys normally look for in a project boat and what things should I avoid for a first project boat? Should I avoid rotten decks? Avoid aluminum since I can't weld?
A few other questions
- How can I tell horsepower rating by looking at a boat without looking it up online? A am asking because a lot of boats around here have no identification on them for some reason making it hard to tell horsepower - I want something in the 75-115 range.
- If I go aluminum will I need to learn to weld so that I can weld brackets to hold the deck and such in?
- How to tell how a boat will handle rougher water without a sea trial - I doubt cheap boats in need of restoration will be sea-worthy enough to test.
- What things should I expect to run into that are not obvious to someone new to boat projects?
buxmj
I am no expert, just giving my opinion. If you are looking for a boat to restore and it is fiberglass, the more rot the better, easier remove and get down to the original glass. Good luck and please share your journey!
matt167
You generally don't weld on an aluminum boat that is built. If it needs welding, it's got problems. Leaking rivets can be re bucked and then sealed with Gluvit or even 5200. depends on how far you want to go.. Transoms and decks are easier on tin boats, but generally they are not as water tight.
SkaterRace
I've never owned an aluminum boat so forgive my ignorance, how do you attach the deck and seats to the hull if you don't weld on brackets?
matt167
wooden deck, and generally they are riveted in place, but some use self tapping screws. The 'brackets' are the ribs and framework which are there when the boat is built
