What to do for de-winterizing
ericp501
I checked out the stickys and I went out and got the muffs. I just want to know for sure what I should check/do before I hook on the muffs and turn the key.
dingdongs
Re: What to do for de-winterizing
if you done it you should know if you removed the drain plugs.if not make sure there all where they should be remove rag from inlet of carb if anyone blocked it check battery is fully charged and all lubricants full.connect hose to drive and wurr it over.may smoke a little as as burning off fogging oil.check for any leaks or dissconnected hoses etc
ericp501
What do you mean hose to drive? Sorry I'm a newbie
