My boat:
1985 Wellcraft Scarab I
Originally equipped with a Merc 260 alpha 1 gen 1 combo. The engine has been replaced with a GM goodwrench crate 350 and many parts from the merc 260 were transferred to the new block. This is how I bought the boat.
For the people that don't like to read the detail --> My actual question is; What thermostat should I be running? It turns out its not very clear...
The details. I got the boat at the end of the season last year and took it on a quick lake run to see what was needed. The temperature had bothered me a little as it was ranging from 170-190F. I just completely resealed the upper gear housing and replaced the entire water pump in the lower unit with a sierra kit. I replaced the base, housing and impeller. Of course the gaskets and plates etc were replaced too. I looked at the thermostat that was on the engine and it appears to be a 160?F thermostat. Now I have seen people say Mercury recommends running 142? t-stats and others say 160? t-stats. I know that if the engine was in a car or truck it would most likely have a 180 or 193 t-stat or something like that.
Now my boat has through hull exhaust only so there is no need to worry about melting parts in the outdrive as the exhaust is not routed through that. Obviously the exhaust does still encounter the risers etc so maybe the temperature is lowered by design for one of those components?
I put the t-stat that I have in a pot of water and observed the temp that I start to see activity. Its about 175?F by the time its really open. It does seem to start opening around 160 though. I was always told thermostats are designed to fail open. But can they fail in a manner where they are slow to open? I've never really replaced a thermostat on a car/truck because the car was not getting to operating temp. Usually it would overheat during idle and during cruise with more water pump pressure it was better. Or it was just overheating all the time.
Thermostats are cheap and I should just replace it. Fine.. but which one SHOULD it be? What do other people with GM 350's in their boats run? There's gotta be a whole mess of people with this super common setup? Why is there so much controversy over it?
Also where do I get a new brass retainer? Ive included a picture of what I have for a thermostat and retainer.
Thanks for any info/help!
Ethan
Ethan
