driver_dav
Thread starter- Joined
- May 1, 2013
- 96
I have a Maxum 2100sr, 1996 with a 350 in it, I just rebuilt the engine, I have a battery that is 15months old the label two numbers- 1000 CA @ 32 degree, and 800 CCA @ 0 degrees. When I tried starting the boat it was turning very easily, I hooked my truck up to it and let it sit for a bit and then it would turn nicely, fire up then die, repeat. I dont know if the battery is bad from sitting for 15 months I did charge it over night, or if its just not enough juice, should I get it tested and if its bad replace it with the same size or do I need to upgrade?
