FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I just put new stator,trigger and regs in my engine ( 2004 150 Saltwater Merc. carbed engine ) , and just bought a new battery. On my Furuno FF the volts read 14.3 - 14.4 , shouldn't I be seeing 14.6 ?
The meters vary a little. Also, if there's blocking diodes so that meters can run off either engine switched power or boat master power, they will be about a half volt low.
When things work well, note where it rides. Then if it goes high or low, check into it.
You have 12 volt batteries. A 12 volt battery is a "battery of six cells" each of which provides 2.1 volts. 2.1 xs 6 = 12.6. If you are taking readings with the engines running the voltages you are seeing are the charging voltages. As long as they are above 12.6 the system is charging. Your numbers are OK. With the engine stopped voltages should gradually drop back to static 12.6.
