Erik-The-Red
Thread starter- Joined
- May 2, 2007
- 21
I've searched but come up empty. No solid answer, just folks saying "I think you can use this" or "should be able to use power steering fluid" and stuff like that. So, what do I use? Its a 2001 Volvo 3.0 SX with power trim. I'm headed to the lake in the morning and need to add some to the reservoir. Hopefully I can add PSF or ATF, because I have both. Also, is it ok to mix fluids? For example, if the reservoir has ATF in it, can I add power steering fluid without first draining all the ATF? And how full should the reservoir be with the trim all the way up (rams compressed)??
Thanks for any help!
