What part is this?
Jaynen
I got a 1974 Mercury 500 thunder bolt with lightning energizer ignition and I was just wondering what part this is in the picture I have attached and circled in green. I just finished rewiring the internal engine harness so that I can attach any tach I want using the rectifier wire. And I noticed that this wire to this mercury switch was all coroded. Is this mercury switch the engine kill or does it have something to do with the tachometer? Do I need to have it on? Any help would be great thanks.
M
Maxz695
Guest
Re: What part is this?
the mercury switch is a kill switch for when the engine gets tilted up it shuts the engine down when this happens . It,s good to have it there although you can disconnect it. I don,t believe it affects the tach
Jaynen
I wasnt expecting that to be the function. I dont think I would have found that awnser by searching. I am gonna hook it up anyways though. Thanks for the reply!
M
Maxz695
Guest
No problem yea it,s a saftey feature so if your reverse lock is broke and the engine raise it wont cut you hand (Head) off
