what outdrive fits my motor
roachy20
Hello, I'm new to the boating world...I just bought a 1988 Starcraft Medalist 1901 with an OMC 6 cylinder motor... The boat needs a new outdrive, so I was wondering what outdrives fit this motor? Will only the OMC Cobra fit or can the Mercruiser Alpha one fit? Any input would be great...
Thanks
HT32BSX115
Re: what outdrive fits my motor
Howdy,
Well you didn't provide enough info....
If it's a V-6 that originally had a Cobra installed and the gimbal is still there,
you're stuck with finding another Cobra.
If you want to switch to a Mercruiser, you'll have to find a complete engine, gimbal and sterndrive (with a similar engine to what you have) if you want to switch to a Mercruiser.
That would be your best bet if you could find a Mercruiser set up.....Then at least when you're done, you'll have an engine/drive made by a company that is still in business.
Otherwise you'll need to find a used/rebuilt Cobra drive to install.
In either case, you'll need a complete OEM service manual if you want to do it yourself.
Regards,
Rick
