zonaman
Thread starter- Joined
- Apr 1, 2005
- 118
I've got a 1995 Mariner 2 stroke (serial number 0G242454). I was at the lake and was starting fine and running well. Then it wouldn't start as if kill switch was pulled (it wasn't). It has spark to all 3 cylinders. I can pump gas through fuel pump and past filter up to carbs using primer bulb. I noted that when I partially unscrewed the top 2 carb bowl drain screws, no fuel came out. There was about 1 gallon of 6 month old Stabil ethenol gas treated fuel in the tank along 8 gallons of fresh, treated fuel. Didn't detect water in fuel as far as I can tell. Should I be looking at my fuel pump (photo attached) on this and, if so, how do I test it? Should I be looking at something else? Thanks in advance for advice.
