What motor will this prop fit?
shallow hull
Cleaning out storage shed at lake house. Found 3 used outboard or stern drive propellers. They were probably replaced or were spares. The problem is that I don't know what engines they would fit. I am assuming that props are not interchangeable between engine manufacturers.
I'd like to sell them around here but I don't know how to advertise them.
Any help on how to match a prop to a motor?
Thanks !
Honorary Supreme Mariner
????----Posting some pictures or the numbers off the props might help you.
Yegboats
Most,but not all props will have some sort of part number on them. If you cant easily see the #s clean the prop and look again. #s can be found between the blades,under the blades,or around the center of the hub where the prop nut goes. Google the numbers.
