what motor should i look for ?
procraftguy
Ok i have a 1988 procraft 1780 fish &ski i got it withought a motor and restored it got a 50 hp force motor for 80 bux it run perfict (after some tinkering )i want to pull tubers and mayby skiers pluse get it to go faster then my 22 mph (gps) i have know its rated for 150 i dont mind used but the evenrude etech has got my attention but cost quickly took care of that so fire away i just want easy to find cheap parts for used if possible ty
procraftguy
Re: what motor should i look for ?
I really would like somthing easy and cheap to fix basiclly if i need a part i can get it and not break the bank i like the force but upping hp seams doesnt get u much speed i was reading the 125 runs about 35thats not much better then my 22 mph with 1&1/5 less hp
roscoe
Look for an Evinrude or Johnson, 90-115 hp, mid 1980's or newer.
And on the water, 35-40 mph is a lot, compared to 22.
procraftguy
Ok i am looking at a 85 hp mercury thonder bolt ignition? Good or not a quick look at parts available and diagram it looks fairly simple any thoughts i can get it for 400 and has tilt trim no controles
boobie
If it has no controls you'll be sticking more bucks into it.
procraftguy
I found a 125 hp evinrude 1986 or so for trade on my 50 so hope it works out i hate letting this go it runs so good but i hope this works out hey i got tilt and trim now atleast as well
procraftguy
Also ty for input as to what to look for
Home Cookin'
well since you've already bought the motor this comes too late, but you usually want no less than 75% of the max rating. However, 150 sounds mighty high for a 17' boat but that depends on the hull. I run a 70 on a 17' that's set up like a "fish and ski" (dual console bay boat hull) and that's all the power it needs.
procraftguy
Thanks for input home cooking the 50 was way small but i wanted to go fishing this summer after all my work rebuilding boat and it was 80 bux need i say more. As for the 125 i meant 120 (rvo v4) is 3 times heavier and when im up front the boat is more stable in rough water also runs out perfict about 43 mph and not bad for a 1400 lb fiberglass boat (without motor)
