what makes timer bases fail?
Bob427
gotta know what makes this part fail
is it because its a solid state part and well after so many triggers thats it?
or is it something else that makes this part fail
Bob427
Re: what makes timer bases fail?
anyone?
boobie
Are you having repeated failures or what ??
Bob427
My outboard is a 1995 70hp
I just changed the base out the one that I took out has a date stamp of 2008
It just seems odd to me that this motor is on its thrid base
seahorse5
There is no way to test for it, but very often the power pack will cause a timer base to fail. Your 70hp timer bases uses logic chips to change the start timing - QuikStart - and they are very critical to correct voltage and any voltage spikes. Replace the pack and timer base together if there is a history of multiple failures. Also check the coil grounds, wires, and for any cracks in the insulation as a marginal coil can affect a power pack which in turn can affect a timer base.
Do not use plugs besides the factory recommended "Q" series which use a suppressor internally, not a resistor like other brands.
