What is this
Mariner25?
this is on the fin on the lower unit. I don't know what it is or its purpose. Any ideas?
jimmbo
Re: What is this
looks like a torque tab. might be causing your hard pull to the right your other post mentioned
Mariner25?
Re: What is this
Jimmbo. It is facing the same why the trim tab is. Think it may be a problem. It looks like it is supposed to help.
oldman570
Re: What is this
Looks like someone broke the skeg off and added some kind of junk to it rather than replaceing the LU housing or getting a weld on replacment skeg.
Oldman570
Faztbullet
Re: What is this
It is a T&H Marine torque tab.....
A simple solution to eliminate or reduce right hand steering torque. The Torque Tab is inexpensive, simple to install, and does not reduce speed. Cast aluminum construction complete with installation hardware and instructions.
Counters Outboard Torque Pressure on Steering Wheel
Improves handling, performance, and safety
Inexpensive and Easy to Install
Cast Aluminum with Stainless Hardware
Fits any outboard lower unit skeg
Can be painted to match lower unit
http://www.thmarine.com/products/Outboard-Performance/Outboard-Torque-Tabs/Torque-Tabs
Mi duckdown
Re: What is this
Fazt. That is a new one on me. How do you come up that Sh$t. What a font of info.
The only problem IS mariner 25 has another post with the Problem/???
Mariner25?
Re: What is this
Sorry guys. I posted the other post then noticed this. Thanks for the info.
Faztbullet
Re: What is this
How do you come up that Sh$t?
35 plus years of turning wrenches and racing outboards....:D Mariner 25 what is your model number as you could have the XL and if lower unit is too deep in water torque can be a bear..
Mi duckdown
Re: What is this
he claims on his other thread that he is running a long shaft on a 20 inch transom. serial no. a108907
